I plan on testing out a few borrowed carbs on my GTX..between now and this spring. Can anyone steer me in the right direction on what electronic equipment I should be purchasing to set up the carb systems correctly? The exhaust system has a bung installed on the header collector,which was done for chassis dyno-testing,last spring. Thanks in advance for your opinions! Randy B.
