It does look easy. And the round tubing subframe connector also works easy as well.
I went to look at a Dana last winter. The guy had cut a pocket hole in the bottom of the frame, bowed out one side and drilled a hole through and slipped the front spring eye up into the pocket.
John
1971 Satellite Sebring Plus - 14.46 @ 95.43
1977 Road Runner - N/B 11.02@ 119 Drag Radials
