I recalibrated one some years ago via resistors, wired them in series at the fuel tank with the sender wire. Had to keep adding resistors in a parallel bundle until I got the right amount (lots of crawling under the car with resistors and then out to check the gauge!). After hitting the right combination I sealed it all with heat shrink. This was for installing a used OEM sender so it's not the same situation.
As I recall it was off by 1/8 tank at one end of the gauge but was close enough for me. It either read E at a true 1/8 tank or never reached full.
I recently installed a new Spectra Premium sender in another car and it's off by 1/4 tank. I think this one needs the float arm rebent. I'll empty the tank, fill it with 6 gallons (24 gallon tank) and see what adjustment needs made to put the gauge to 1/4 tank. 6 gals should be below the gasket of the sender and permit me to R&R teh sender without spilling fuel. Can then maybe hold the float to the top of the tank somehow and see how the gauge looks for full.
Parts I seek:
driver doorpanel, 65 Sport Fury, prefer black, needs to be 7-8 on 10 scale, might buy set
16" x 6" Dodge truck wheel(s), from early 70s?, takes 9" dogdish - need for a research job so cheaper is better.
69-73 C-body caliper brackets and/or splashields
Send a PM.
