Cut about 1/8 inch off the transmission input shaft where it goes into the pilot. It is bottoming out in the crankshaft and binding up.
Bingo! I'll take the bet that this is what it is. Mine did the same thing. You can easily test if this is it by loosening the 4 trans to bellhousing bolts and try shifting it when it's running then. I had to grind off about 1/2 of an inch from the input shaft to get clearance. My crank just wasn't drilled deep enough, or the scatter shield was shorter from block to trans.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
