I WAS GOING TO USE THE OFF SET SPRING HANGERS. I DIDN'T NO IF THAT WOULD HELP OR NOT.
I made a new front spring perch and located it next to frame rail, otherwise the tires wouldn't clear the springs. I used the offset shackles on the rear too.
