That's a neat ol truck you found! I had a 56 with a 440/727 in it back in the early 80's. Mine had the big back window also. Sheldon is right about a straight,empty road! If it has the stock steering box in it.....it ain't any bigger than your fist and requires considerable effort to keep up with the steering. Good luck.
You pair that with the tiny chain steering wheel that is currently on it and with was probably a bear to drive.
Rick
