On some roots blowers that I'm familiar with, they make many different snout lengths so you can tailor it to your setup by changing the shaft and the snout housing.
I know dyersblowers.com sells a roots intake for small block LA mopar, you'd have to redrill if you have magnum heads. Only problem is their SB mopar intakes costs an arm, leg, kidney and your left lung! $1300
Your not kidding on the price. They don't make one for a Magnum yet. I found one at INDY and it's $634. I can live with that.
Jack
the snout mount face is 5" from the #1 blower stud if that helps any now that you found an intake.
I think what I will have to do is pick up the intake and a blower minus the snout if I see a smoking deal on one. Then get my measurements and order a snout and pulleys.
Maybe even buy a complete setup and then sell what I can't use to help pay for what I do need. This is if I see a great deal on a used one.
Jack
