Re: reg slicks to drag radial lower et
[Re: Monte_Smith]
#845384
11/04/10 12:33 PM
11/04/10 12:33 PM
Posts: 8,165 Left Coast
BobR
Left Coast
The radial, of comparable size, provided you can hook it, will be faster than the bias tire, every time. The radial tire construction, is simply better. Yes the sidewall is stiffer, but the tire as a whole is stiffer. The tire stays more "round" during the run, which is quicker and faster. We run both slicks and radials. With identical tune ups and identical 60fts, the 330 and 660 numbers, are quicker with radials, EVERY time.
Monte
But when the hook goes away it won't recover without pedaling on a car with any power. Even when pedaled it's hard to get them stuck again. I know these tires are resposible for some fan interest.
