The pick up coil is much more likley to be bad then the ASD relay, check for power to the coil on the + side when you first turn the key on should power up for 3 seconds if you have power there the ASD is working properly. the fuel pump and coil are powered by the ASD but the computer will not turn it on if it does not see a signal from the pick up coil while cranking.
Kevin
