Greetings, I am installing a 360 from a 1978 Ram Charger into a 47 Dodge pickup. Installed a K-frame from a F-body in the 47. Replaced the stock 4:88 rearend with an 8.75 from a 1964 B-Body. I got a 727 (4x4) and torque convertor with the engine. I found a low mile 904 from a mid 70's Chrysler that was behind a 318. I understand the 318 is internal balance, 360 external. So, will a 904 with the 727 touque convetor fit behind the 360? This is my first attempt at such a project, so some/any advice would be helpful. Thanks.
