Quote: Another vote for no spinning the tires(blip) of the throttle. I roll completely out of water to where the previous burnout was done. Set line lock and don't be afraid to get the ball rolling, get on it strong and fast and be ready to go to third as the tach sees fit, 1 second or so in high gear, let off the button and stay in it till rear starts to grab and off the gas.
if they don't put down enough water ask for more. we are not bashful about stuff like that. i would not trust most burn box people, they don't care if you start in the same spot or not or if ur burnout is the same everytime. i've seen a lot of guys in door cars open the door and look for themselves.
