Re: A body power steering auto column shift to floor
[Re: west]
#838893
10/26/10 05:53 PM
10/26/10 05:53 PM
Posts: 639 Wilmington, NC
donbarnes
Not THAT Don Barnes!!
Wilmington, NC
Remove the bowls, cut the shifter tab and gear indicator tab off, fill them in, then repaint.
\ this is a quick and cheap way of doing it. Even if I scored a manual column I would sell it and do it this way. the finished product will look way nicer.
+1 here, not hard on the Mopars to cut off the mentioned pieces, fill, sand and repaint it to make it look like a floor shift column. A little time consuming, but quicker than looking for and changing out everything to a 4-speed column, and you can't tell the difference when it's done.. ![](/ubbthreads/images/graemlins/thumbs.gif)
