Find a 4 speed column? Sure. They are everywhere, and cheap too. I see them for $5 at every swap meet.
NOT.
Heres a better idea. Look in your local wrecking yards for 72-80 Dodge trucks with 4 speeds. The steering column parts are very similar. I have converted several column shift steering columns this way. They will not have the key lock lever like all the 71 and later cars did, but that wasn't an issue for me.
I don't know about 72-80 but my 82 truck did have a key release button, so if you find an 82-up column, it should have what you need. And they are easy to take apart. I have done several this way. Good luck.
Back from hiatus
