Thank you guys, I thought that was the way. Green brngs are currently out of my budget. Getting layed off for July shutdown this year, with three more weeks in August and Sept. ( Ford )
Clean, inspect, and repack what you have if they are good. They are a superior bearing to the green bearing anyway and the couple of minutes more it takes to install them and as often as it is done (maybe once in a lifetime) just doesn't make sense.
