Which side does the adjustable axel belong on, I beleive it's the right. ?? Am I right? And why would it matter?
Right is the side the factory chose and is in manuals for uniformity sake. It doesn't matter which side you choose to put it on or if you have to under circumstances put in a used axle with good bearings and it has the adjuster use it on the other side too, using an adjuster on both sides. just set one side and and adjust the preload from the other.
