you would want to select the octane your going to run (pump gas I'm assuming)along w a stock cam? I'd select one of KB's hypereutectic pistons that'll give you a CR of ~ 9.5:1 along with some regular garden variety single moly rings (low tension/file fit not needed or wanted in your case)
Hughes web sight might be a good starting place for you. Lots of combo's to look at.
Fastest 300
