These are MP P5249157
.920
the original .960's are long gone
http://chucker54.stores.yahoo.net/torsionbars.html
http://chucker54.stores.yahoo.net/mop920diambe.html
Then those bars should be stamped 780R and 781L As long as you have them on thier correct sides. It doesnt matter witch way the bar is installed front to back, as the twist will be in the same direction.
But since they are aftermarket bars they may be stamped on only one end. If thats the case, you will want to install the stamped end toward the rear for a easy visual identification for you or anybody else for future identification.
Further, the "Even" numbered bar is always the ":Right" side bar. mike
