If a Tbar was suspended in air & you walked up on it from the side and extended your arms and grabbed the left end w your left hand and the right end w your right hand then applied a bit of torque to each end clockwise & held it on both ends then turned (rotated) your body around halfway a half turn you'd still be applying torque to each end the same way (clockwise)so the bar would still be getting twisted the same way
