I haven't find any LED bulb to get totally satisfied.
Main reason is, our lights housings are not set to the LEDS lights projection. You need allmost a 300º degrees light projection to set fine the lense ilumination.
yes they are brighter, but focused straight forward Thats the reason why they are brighter, maybe same lumens focused at just one point instead all around.
The only advantage for those is the low consumption
With a Charger born in Chrysler assembly plant in Valencia, Venezuela
