Quote: Thank you for the compliment. Unfortunately the engine is out of the car with #5&6 rod bearings spun and not enough $'s to fix it right now. I was hoping to make it with the Duster my father and I have but that's not quite ready to go either. I may be there to spectate if my friend with his 413 powered 31 Ford coupe decide's to go. If I make it I'll try to stop by and say Hi and check out your car. I assume you'll be there with the Cuda in the pic. Awesome wheel stand by the way. Here's a pic of the coupe
yes will be there with cuda and stop buy say whats up hope to see u there
