Quote: The car is running good man! Took my smallblock car out that Saturday at the Plex also, weather wasn't as good as Sunday but it ran a 9.70 with a 6.10 1/8th mile pass. Not to bad considering it has too much gear in it. I was in the 1/4 finals in both classes until my new tranny broke. Think maybe it was a input shaft, rpm just shot up when I shifted to third and have no forward gears.
Good job going rounds Jacob. I can't remember, but if you are running a 727 I still have mine on the shop floor that you are welcome to use for the bracket finals. Just let me know.
Thanks Brian but it is a 904. I am going to run my Challenger at the finals instead. Now I will have all winter to pull it out and get it fixed; again.
Ok Jacob. I still have the converter also, so it would only be a driveshaft away from working. Just wanted to offer it up if you needed it. Good luck next weekend.
