Did you PRESSURE check the converter? Mine had no visible cracks but 25 - 30psi in the snout and some water around the weld showed a crack that was over 1/2 way around right in the middle of the weld. The firast time I checked I was so sure it was fine that I put a new pump seal and bushing in, moved the vent to the rear, put it all together, tested it, and had to tear it back out again.
11.33 @ 118.46 on motor 10.75 @ 125.35 w/ a little spray Now, high Speed Open Road Racing - Silver State Classic Challenge, Nevada Open Road Challenge, Big Bend Open Road Race Rocky Mountain Race Week 2020, 2022 2.0, Sick Week 2023
