I work on Ford vans all day and the only difference internally is the exciter ring on the carrier and it can be removed. Not sure as far as tube diameter though.
can you explain? is it there for the abs? also, is there an abs provision on top of the housing for this? im wondering, if the exciter ring is removed from an abs rear, would there have to be something to take up its slack i.e. do the abs rears use a different cover or something?
