Higher stall will make more heat. if you just tool around town with that lower stall your stock cooler should be ok, but if your going to stall/flash it a lot and close together it might heat the fluid good.I would at least run a deeper pan that will hold 2 to 4 quarts more.
thanks I allready have a deep pan and pom. ill run a external cooler also.
