I know this topic is a little old but I have a question John. I didn't know about the max cooling stator support change in 1974. I used an early front pump with the metal vent baffle but I'm not sure if I used a stator support with the max cooling changes or without the max cooling changes. I do know I used a wide bushings stator support. Is there a problem with using an early front pump with a max cooling stator support and vice versa.
Thank You
