Quote: IMO you should not color change an original collector car, It's expensive to do correctly and just as expensive to reverse should the next guy want to, this fact usually reduces the cars value by the cost of reversing it. My advice? sell the car if you don't like it and use the money to buy one that has the combo you like, it will be worth it in the long run. You asked for opinions, there's mine.
