Went through everything again...you name it I checked it. After a full body fit I had an idea I yanked the pvc tube off the back of the carb and fired it up. There was zero difference. I got the thickest oil out I could find and covered the intake mating surfaces. Fired it up and watched the oil get sucked it. New gasket should be here in awhile.
