I agree with Stumpy. I think the tube is broken off.
Where is the bracket that is welded to the tube and bolts onto the engine mount to hold it in. It should take very little force to slip that tube back in the block and bolt up the bracket to hold it in. Post a picture of what you have left and maybe it will help us help you!
