I bought a DANA 60 w/4.30 gears last year how much rpm difference at the stripe ....I hear about 300rpm ...what do you guys think?
Specs 440 eagle rods
275 60 15 Drag Rad.
8"ATI CONVERT
WITH 4.10 I was going thru @ 6600 6700
I see a lot of responces concerning the math, you have to remember that if you make the 1st and 2nd gear changes at the same RPM with both rear gear ratio you will be further down the track with the 4;10 than you where with the 4;30 so the RPM drop(EDIT: at the finish line) will not be as calculated due to the car going into high gear with the 4:10 further down the track. It won't spend as much time in high gear so it won't accelerate as fast as it does in high gear as it did with the 4:30 Don't be surprised to see very little ET and MPH changes with that ratio change Do the change it may go quicker and faster, not much probally, but some
