Works great, especially with a Edelbrock head. You need to be paying attention to pushrod clearance, make sure you have the right head gaskets, and you'll need the right pushrod oiling lifters. Really a simple, effective set up.
RIP Monte Smith
Your work is a reflection of yourself, autograph it with quality.
WD for Diamond Pistons,Sidewinder cylinder heads, Wiseco, K1 rods and cranks,BAM lifters, Morel lifters, Molnar Technologies, Harland Sharp, Pro Gear, Cometic, King Engine Bearings and many others.
