Quote: I have many miles on this set up, it works, the rotors are wearing nicely and are not warped...I ran for years with the stock stock two piece rotor/calipers with carbon metallic pads, no problems with the rotors, just some fade and poor pad life. [hint it's in the bearing preload] Care to elaborate? I could use a good ninja bearing preload trick! PM if you'd like please.............
