Guys routinely go low 1.20s and high teens for 60ft, in 3000+ lb cars, on the 275 Hoosiers. The Hoosier is not a "true" radial and not sure how it got the DOT rating for a radial. It is way closer to a bias tire, than a radial. I know the Mickeys work, but you can hit the Hoosier harder initially.
Monte
I am glad you posted this Monte... I spoke with M/T about a drag radial or the et streets.. My car is a 4 spd and per the guy at M/T I do not want to use a drag radial with a brake or a clutch transmission The said for me to stick with the ET Streets as my clutch car would need the sidewall flex that the radial does nto have,,
2011 RAM3500
1967 Fastback Barracuda with some go fast goodies.
