Guys routinely go low 1.20s and high teens for 60ft, in 3000+ lb cars, on the 275 Hoosiers. The Hoosier is not a "true" radial and not sure how it got the DOT rating for a radial. It is way closer to a bias tire, than a radial. I know the Mickeys work, but you can hit the Hoosier harder initially.
Monte
