Quote: In the interest of safety, get some stock parts modified to work. The extra 1/2 pound is well worth it! These arms were cut off and welded back on at the right height and length. They have proven to be extremely durable.
or get lucky and just use a stock lower ball joint arm installed on the opposite side with no cutting and just a little bending
I thought you were not supposed to heat front end components?
