Hi,
have tried mopar direct fit 7mm wires, new just before driving to the nationals last friday, msd 8mm today, new cap + rotor today.
Test wire was the extra wire from msd set installed in #2 on distributor and sparkplug held on the engine block to see if it would spark.
As I noted, engine will start and run while I hold the plug to the block, Note that #2 cylinder has nothing hooked at this point. When I lift the plug i'm holding to the block the engine stalls.
firing is ccw 18436572 checked that many times.
Have you tried a new plug in #2. Sounds like the plug is shorting to ground under load.
