Hi,
No gap to set on the optic,it sees light or not.That's in now.
When the mag pick up was in, I set it with a brass .007 shim.
Thanks Tim
ok missed that part, try shaft coller might be bouncing? watch dizzy spining with cap off have somebody turn key with plugs out, might be bent? ohm out all your wirs? drill vent hole in cap wont cross fire/carbon track. some thing that helped me
MOPAR OR NO CAR
