Chip, I don't know if this helps you out but i crawled under a few at the local JY and a couple (ford and gmc) both were 3/4 tons and both had a "60" casted on the center section,i believe on the lower right hand side(on the web).Let's see if Dr. Diff can concour with this info.
Jeff
Ps they had no older Mopar trucks,Kinda funny HUH.
EDIT* there is also a "C 30255 on the upper right hand side*
68 CORONET R/T BEST MACHINE BUILT EFI'd TWIN TURBO(UP and RUNNING !!)
03 Mach1
