The Pro Systems dominator I have on my hemi cost $1000.
I was quoted $1150 for a custom SV1.
I think the jury is still out as to just how much better the SV1 is than a regular dominator. Glad I waited to see some results before buying one myself. I'll be sticking with my current carb for now.
whens the next time you are going to the track?
I'm up for going anytime.
well as soon as I get my junk back together (hopefully soon)Ill ship ya my SV1 to run some back to back hits with your dommy! just put it back the way I sent it to ya when your done
Or you could send it to me and I will try it at Bristol next month
Chip, I need to give you a call soon.
Ron you can run it also. you guys can put some hits on it! this one has the 110mm blade and is 1212 cfm... as said you can change it around just put it back! besides atleats we will have some REAL comparison results! ill order up some extra blue gaskets from patrick as these are a little different than the holleys
Mopar Performance
