Locking transmission dip stock for any car faster than 10.99.
If you fuel cell is plastic - you need a ground strap to the filler cap outer ring.
Neutral safety switch is needed.
Helmet must be snell 2000 rated or newer and a 3.2A/1 fire jacket.
3/8" battery hold down bolts, battery in trunk needs an on/off switch on the back.
Aftermarket axles if faster than 10,99.
Driveshaft loop.
Metal valve stem on all four rims unless running tubes.
Coolant overflow bottle
Two throttle return springs.
I am good on the above except:
I am running a stock dipstick, stock axles, 5/16 battery hold down bolts (but in a covered, bolted metal box), my coolant overflow is a "venom" energy drink bottle.
Does the overflow bottle need to be sealed? I am not prepared to buy axles at this time (will be switching to rear discs and possibly a different length axle). If they are serious about the axle inspection maybe I should pass on this event. The other items are minor. I don't even know if the car will hook and go faster than 10.99.
Do you think that excuse will work for a few passes?
