Re: Engine painting with spray gun
[Re: Ryan_340]
#755995
07/23/10 06:22 PM
07/23/10 06:22 PM
Posts: 1,209 Fredericktown, PA 15333
maundmotorworks
Stealth poster
Stealth poster
I am tired of the peeling rattle can paint , so the engine is out and getting cleaned and prepped for a re-paint. I have heard that automotive paint will hold up better. The color will be Hemi orange. What is the best type to use, how mutch will I need? Also please post any pics., tips, tricks, and other supplies used. Paint codes would be handy also.
I do all my engines including customer engines with auto paint and clearcoat. For Race Hemi orange, the color actually cross-references to GM Omaha Orange. Don't laugh, it's actually true. Anyhow, A pint of base and a pint of clear can do the whole job and still leave a little bit leftover in many cases. I have tried Dupont in the past, but always had trouble with it. I stick to Martin-Senour Crossfire products or Limco, as I have found by trial and error that many of their hardeners and their thinners will work with each other. As always, the biggest priority is the prep. Clean it good and make sure you mask everything real good so as not to have a disaster with the overspray. Another thing I do is use less hardener than suggested in order to let the clearcoat flow out and fill nice. It still cures good and hard, just takes a little longer but its well worth it. Just my ![](/ubbthreads/images/graemlins/Twocents.gif)
Maund Motorworks--supplier of high performance Mopar engines--specializing in B, RB, and Hemi. www.maundmotorworks.com
