Find a socket & extension that is a close fit on the inside diameter of the freeze plug and tap it in. I highly recomend the deep plugs, they have a longer lead and are a lot easier to seat. Just did one with the engine in the car...Getting them out is messy, but just don't damage the cast iron that holds them in. Also, using some sealing goo is cheap insurence not to have any leaks.
'70 Cuda,...605 EFI Hemi Street Car (6.20 best pass, 1.33 60ft)
https://www.youtube.com/watch?v=WYw6RA-k5Bk (6.25 at 108.75mph from inside car)
https://www.youtube.com/watch?v=3zQEb9uxFng (6.25 at 108mph from outside car)
'66 Barracuda AWB Stretched nose Blown 440 Car in build stage
'71 Duster Drag Car 400 Low Deck 512 best 6.002 at 115.44mph
https://www.youtube.com/watch?v=Znuo3jMUXTk
