no havent checked that but the last time i used the brake it was fine. just have not used it in about a year . is it possible the seleniod is bad or weak. i will check line pressure.
I had a problem with a older T/A brake that had a
machining issue... both me and my tranny guy had the
same issue... he called them and they sent out 2 parts
for both of our units... a wall in the brake was flexing
back and forth with the pressure and finally cracked
and it would bleed off pressure allowing it to creap
and finally wouldnt hold at all.... since then its
been great(about 8 years now)
