I just got a dana 60 rear and it has numbers stamped on the gasket surface under the rear cover the number is 02573 what does this mean? It also has been narrowed and I can't read the date code on the axle tube. And yes it does have the three bolt holes for the pinion snubber mount.
Thanks, Bryan
It's narrowed so I'll ask the stupid question , what do you exactly want to know ?
He wants to know what the number 02573 means.
Why? I don't know, it's no longer good for a resto.
