Quote: Truck Dana, 29 inch outside to outside, too little room but run 2079-1 Goodyears with 17.8 section width.
Hey Greg. What's your frame dimensions since yours is also a 65 Dart? Also, did you open up the size of your rear wheel openings? How about the fronts to run bigger front tires for better roll out?
