Quote: Are they really that cheap that they can't spray another 320ft.... ....I've raced at Norwalk and left my shoes stuck at the traps while walking the track at night. Maybe Bader should make a move on buying NHRA
nhra says that spraying the last 320 feet pass where the fueler shut off chunks the tires on the fuel cars...
And it does. Still no reason to hose the P/S cars.
I disagree. You chunk a tire at 320mph and it can be really bad. The Pro-Stockers can easily fix this issue.....it's called putting some attack in the freaking wing. Bunch of whiners. They run their crap on such an edge of aerodynamics, that the least little bit of slippage makes them ill handling. But they won't dare put any wing in it. That might scrub off a mph. Whiners. I don't see the alky cars having these issues after the 1,000ft mark....why is that...oh yeah, they USE their wings.
