make sure there are no vacuum leaks and that the motor is not running lean,
issues
If all of the above checks out then it may be time to start looking at the radiator itself
Richen it up, I'm sure it will help. Clutches on the fan go bad all the time. It will run hot when that happens, been there, done it more than once.
