Sounds like power is going to both sides of the circuit.
What happens when you remove the dim bulb?
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
