Both doors or just one door? The switches are are ground switches so most likely the switch is grounding out when the door is closed
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
