Re: R1A-W5-W8 Motor Being Built!
[Re: HerboldRacing]
#731471
06/23/10 04:58 PM
06/23/10 04:58 PM
Posts: 8,547 State College, PA
RyanJ
moparts member
moparts member
State College, PA
Yes similar... his will have alot more compression (has a 16 degree angle milled W5 with pretty small chamber), & hair more camshaft.... Yours has more radical piston/bore combo, & too much intake manifold. Both getting dynoed, probably make similar power, but I'd expect the 416 to put up hair better # with the better head/compression & cam. I think his 416 is going to make way more power than he wants, so I'm having to decide if I want to de-tune it a bit with cam.
Yeah - I only need my car to go mid to high 10's at 3000 DA to be faster than most of the guys I bracket race against. I'm tired of being chased down instead of chasing others down. The car weighs 3264 with me and gas in it... but that's with the iron head 340 and stock radiator. I'm sure the aluminum W5 heads and aluminum radiator is going to lighten up the front end a bit.
I also don't want to be one of the guys pouring money into new springs and lifters every season (or after every few races even!). A less aggressive cam means less open spring pressure means it's easier on my wallet. Also less Torque / HP means fewer parts breaking! :-)
Your car is 4 lbs heavier than my Buddies '72 Challenger here in State College that I wrench on.... With 685 HP it's been best of 9.87 @ 137, that was at 1200 DA. Recently it's been stinking hot/humid 2800-3100 DA for last couple times we've had it out including last Friday night & it has been putting up a string of 9.98-10.06's. Mostly 10.02/10.04's.
So we will want to be in the low 600's to get you at least mid 10's in typical 3000 DA Arizona weather.
Low 600's with this kind of combo basically has to be de-tuned. I'm dynoing a 416 Stage 2 Edlebrock motor on Monday that should make low 600's... Low 600's these days is not too difficult with good parts.
The W8 intake is a bit small for that combo, which is going to induce more TQ in midrange so I have to be thoughtfull about traction as well on this thing... We'll see, as of right now I'm probably looking @ doing something in the 262/268 @ .050" range on cam with lift somewhere in the .660's
I'd have at least another 7-10 degree's & .050" lift in it if I was going more aggressive....
AWBDart's 439 ICH head deal there is a pump gas street/strip deal shooting for 680+ HP & it's 269/272 .709"/.691" with a 1.65 Rocker & very fast lobes..... & that's a "street" motor these days... It's got a big $ PAC Spring/retainer & T&D rockers, it should live quite well for long while valvetrain wise.
