The motor was taken out of the aar.
Ryanj freshened it up, and did the 71 intake. Also the p/s exhaust manifold was replaced for the correct 71. Both of the new parts were hogged out pretty good.
I have not done a leakdown, compression is @ 245psi and pretty even across the board. The whole car has around 12passes so far. It's consistantly slow.
Work In Progress- 71' Duster F.A.S.T.- 10.36@130 Smallblock Record Holder.
